Need help...
Need help...
Today I was out flooring the car like always and when the transmission got ready to shift from 1st to 2nd I felt and heard a very loud "clunk" noise...after that whenever the car was floored, the gears shift with this clunking noise...also I noticed that differential fluid is leaking...did I blow my differential? When the car is driven normally there is no "clunking" noise when it shifts...if it is a blown differential do you guys know how much does it cost to fix it?
If it's the transmission mount how hard would be to replace it? From the research I done it seems like it is a transmission mount...I haven't had a chance to check it under the car though...I'll do that tomorrow...what should I be looking for?
