Need help asap PIC INSIDE..
alright, here's pic i just took, engine -right side up- so i just flipped the pic...
green line represents where the windage trey needs to go, bolts to the oil pump on the very left, and then also to the main studs....
i circled in yellow where the problem is...i didn't turn the crank at all, but the rods actually go about another 1/2 further, so its gonna tear right through the trey....seems line my main studs should have been longer...
everything is ARP.
lt1 block, bored 40 over, scat crank, eagle 6" h beam rods. studded mains.
http://www.pix8.net/pro/pic/12089N96hP/446493.jpg
everything is ARP.
Re: Need help asap PIC INSIDE..
Get ya some steel tubing of the size that the tray bolts will fit and will fit the boss on the studs. Cut so the tray just barely clears and get some longer bolts. Grade 8 if you can find them,thats what the ARP's are.Then try the pan and pickup should be no more than 1/2" of of bottom of pan,checked with a ball of kids modeling clay. Heat and bend pickup if ya have to.Don't try to do it cold,it will kink or ya might break something.
Originally Posted by NOMAD
I opted to not use the windage tray on mine. With the ARP stud kit, you just don't have enough length.
-Shannon
-Shannon
did u have the same problem nomad?
cmsmith
07-05-2015 07:23 PM
