Need help with a couple part numbers
I checked around for these part numbers, but I wasn't able to locate them by searching here or anywhere else. These are the parts I'm searching for for my 96 Z:
The bracket with a clip on top that mounts to the driver side of the intake manifold and holds the throttle cable down from flapping against the top of the engine compartment (I think all cars had these, but just in case, I have ASR). The cheap plastic clip has broken and I'm not sure if the part comes as the bracket and the clip, or if you can just buy the clip.
I also need the number for the alignment bump stops for the hood (the ones at the front of the engine compartment--they are black and screw into the alignment posts)
Thanks in advance for all your help!
Daniel
Daniel
Re: Need help with a couple part numbers
Clip for throttle cable GM PART # 20038997 .
The bumper is actually 2 parts:
There is the cap (top part) GM PART # 20038997 (#45 in this diagram)
and the bumper GM PART # 10413888 (#59) (it lists it as the one that goes on the radiator saddle. There is another number for those under the forward part of the hood by the windshield washer tank (#46) (10157703), but I can't verify that the number is good any more. It may have been superceded by 10413888 ).
Shoebox
I tried to get the cable clip, but it said the "part wasn't found." I noticed that the numbers listed in your post for the hood cap and the clip for the throttle cable are the same number. Copy/paste mistake? Would you mind checking the number for the clip again? I appreciate it!
Daniel
Daniel
Brandon Wittmer
12-07-2014 12:15 PM
