Need help deciphering an LT1 Engine Harness
Old 01-11-2010 | 05:46 PM
firebirdStud's Avatar
Exclamation Need help deciphering an LT1 Engine Harness
Hi guys.
I purchased a wiring harness for an LT1 with an Auto tranny from a guy on here a couple years back, as I was gonna convert my M6 car to an auto for drag racing only. Well, plans changed, and I kept the car as a stick for daily driving pleasure. Now I have a harness that I cant seem to figure out what it will fit.
The guy I bought it from said it came from a 95 LT1, but he wasn't sure what platform: IE camaro/firebird, caprice, impala or vette.
I posted it for sale on here, and people are telling me it is not for the Fbody because it has a fuseblock atatched to the harness.
So, now can anyone tell me what it would fit?
Are the caprice harnesses different from the Impalas? I realize that the vette would be different from all of them.
Would there be identifiable numbers somewhere that could help me figure this out?
Pics:
Many Thanks!
Cody
Old 01-11-2010 | 06:06 PM
I researched a little bit on Ebay, and I found this is for the Vette:
http://cgi.ebay.com/ebaymotors/95-Co...item20aee44aea
No fuse block.
But, found this for the caprice/impala, and BINGO, fuse block!
http://cgi.ebay.com/ebaymotors/1994-...09222002r16703
So, what does everyone think? Am I on the right trail or not??
Old 01-11-2010 | 06:21 PM
RUDEDOG's Avatar
That appears to be the one.
Old 01-11-2010 | 06:24 PM
pontiac6269's Avatar
Looks like it could be for a Caprice or Impala. They had that brass terminal attatched to the fuse box like your picture shows. I had a 96 Caprice LT1 car and it had the same thing.
Old 01-11-2010 | 06:34 PM
ok, cool. Looks like we have a winner then?
Anyone else want to chime in?
Old 01-11-2010 | 10:29 PM
Yeah, the b-body cars have the fuse block attached.
Old 01-12-2010 | 02:32 PM
REDLT4's Avatar
Corvette harness would have wiring for 2 knock sensors.
Old 01-12-2010 | 02:59 PM
GREAT! looks like I have a BBody harness. Now, the difference in 94 and 95 harnesses is that there is a pin in the number 6 spot in the D connector for the PCM. Since there are four connectors for the PCM and they are color-coordinated, what color is "D"?
Old 01-12-2010 | 04:31 PM
D on an f-body is blue.
Old 01-12-2010 | 05:13 PM
Cool. Ok, so how are the pins numbered? I cant seem to find that on here anywhere, or I am looking in the wrong locations.
Old 01-12-2010 | 07:58 PM
Another member pm'ed me and gave me a diagram of the pin layout. Looks like I have a brown wire in the number 6 pin slot on the D pcm connector, making mine a 95.
I have been told the only difference between a 95 and 96 is that the 96 has 4 oxygen sensors, is that correct? So this one only works for 95 then, or is it backwards compatible with the 94's?
Old 01-12-2010 | 10:16 PM
Shoebox has the 95 F-Body pinouts on his website. They are marked in red to show the changes in 96/97:
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
In the OBD-II F-Bodys, they added the after-cat O2 sensors, the crank position sensor and the EVAP vacuum detection switch. And OBD-II serial data pin. The 96/97 F-Body PCM requires a different knock sensor than the 94/95 PCM.
Old 01-13-2010 | 02:11 PM
oh, sorry Injuneer, we were talking about the B Body LT1 engine wire harness.
willismoons
02-14-2015 08:42 PM
siguy
11-27-2014 10:07 AM
Fedesna
11-23-2014 11:06 AM
07-04-2005 05:00 PM
Quick Reply: Need help deciphering an LT1 Engine Harness
