Need help please.......
#20
To start the car you will need to hold down the black switch under the clutch pedal and turn the key(that is what I did to start mine with the tranny out).
#21
I know you said everything was balanced correctly with the crankshaft and the harmonic balancer..... But... I installed my balancer and it had been twisted at the sleeve by accident some how so it wasn't true when it was installed in the correct position and it made my car vibrate sooooo bad! I changed it out and put a new one back on my car and everything was perfect then.
#22
