Need Help With Rev Limiter Type Problem
Hey,
Ever since my heads/cam install this past winter, the car hasnt been able to pass 6k rpm. It acts as if it is hitting a rev limiter, but PCM4less swears that they set it to 6700. I dont have a way to scan the car right now to be sure, so is their anything else I can look for as a culprit, could it be valvetrain related?? I really want to fix this since I finally got the new fuel pump in, and the car is finally near where it should be, thanks for the help.
Brandon
Brandon
Yeah, I was wondering if it could be the valve springs as well. I am running the 987's, and Lloyd set them up for me. I thought others were running the 987s with this cam without issues. I havent checked the pressure on them yet. It definitely isnt the pump or filter, and it doesnt feel ignition related. Thanks for the replies.
Brandon
Brandon
MRz, that is the same thing that came to my mind.
The R lifters are VERY picky about rocker arm adjustment. Most have the best results running these VERY close to zero lash or even at zero lash. Even at 1/8 of a turn past zero, they can still "pump up" at high RPM and hold the valves off of their seat. If the valves are doing this and not trapping cylinder pressure, the engine will NEVER run right.
Fuel pressure, opti, etc, would be some other places to check but I would start with the rockers. This is a simple thing that you can do pretty quickly and it is cheep. If this makes no difference, find someone that has some tuning equipment that can help you check things out better and you can see if it is A/F, fuel pressure, opti, timing, etc.
Do a search on the R lifetrs and you will see what kinda problems they have given people when adjusted too tight and how things are MUCH better when adjusted correct.
Lloyd
Lloyd
I agree - it could be that your valves were adjusted too tight - causing the lifters to collapse or "pump up" in the higher RPMs. I had followed the "factory recommended" setting on tightening my valves - but that caused the lifters to collapse or "pump up" - car acted jus like it would when hitting rev limiter. Once I backed off and only tightend the valves 1/4 turn past 0 lash - all was well.
Edit: I too have the "Comp R" lifters.
Thanks for the replies, I will be sure to try re-adjusting the lash on the lifters this weekend. Do you consider 0 lash to be the point where you can feel a resistance being placed on the pushrod while spinning it with your fingers? I just went to the track and was trapping 105mph because I couldnt rev above 5800 in any gear and I was having to shift into 5th near the end
F'n1996Z28SS
08-23-2023 11:19 PM
armedtrigger
02-24-2015 08:30 PM
