Need quick information!!!!
Ok i can get a set of 3.73's with the instal kit new for $150. I think i am going to get them but i have some questions first. My car is a auto with stock 3.23 gears. How much sotp feel will i get and how many tenths will i pick up in the 1/4? Also in the 1/4 if i left my auto in DRIVE will i be able to make it down the track with out shifting into OverDrive?? And the last question is how much will it hurt my gasmileage? Thanks for the help!
Re: Need quick information!!!!
I'll answer the easy ones: The torque to the rear will obviousy be increase by 15%. You might experience a bit lower ET in the 1/4. Your peak tq will come at a lower miles per hour as well as your peak HP.
Probably won't effect your MPG much if at all.
you will feel a big difference, it should knock off about .3 off the 1/4. add a converter and get another .4-.5 off. yes you shoulde be able to put it in drive and make it through the 1/4 without hitting od. shouldnt hurt mileage at all, except for that first tankfull when you are trying it out. also for that price it cant be genuine gm so get ready for any aftermarket to howl like a freaking dog in heat when on the interstate, even some of the gm gears make a lot of noise.
Might as well get some RATECH solid spacers to put in place of the crush sleeves. They don't cost much and might add a bit of strength to an otherwise cheesy rearend. JMHO
Originally Posted by Nick-LT1
About the computer programming my car is a 93 and i heard that i need a new speedo gear?? Is that true??
68camaroboltz
10-05-2015 11:56 PM
RX Speed Works
10-01-2015 10:19 PM
09-18-2015 03:46 PM
NewsBot
09-14-2015 09:20 AM
