Need some Help on bearings
just about to assemble my 383. I got a block and rotaging assembly it has bearing ans he said they only have 500miles on them. I was gona plastic Gauge them to see what im working with and Descided just to get New ones. Heres what im confused on I have a Set of Clevitte 77 bearings (rods and mains) are they any good. I also plan on running 12Psi of boost on the street. (motor is good for it ...Low CR pistons all forged , splayed mains. Now are thoes bearings any good or not what should i buy.
Are the crank journals standard or undersize?
You need to know for sure before you buy the wrong bearings.
Clevite (you'll need the "H" series) makes a fine bearing although I prefer King Alecular.
-Mindgame
-Mindgame
brgs
There is nothing wrong with the Clevite's if they have a "H" in the part number otherwise the ones you have will not take the abuse. The King brgs are great, but high $$$$.
If they don't have an H take them back and get the "H" series brg.
