Need Some Info O Some Valve Covers
I Just Got My Motor In My Car After A Complet Rebuid. New Twisted Wedg Heads , Gold Roller Rockers (crain) , New Cam, New Alum. Piostons, Eagle Crank.when We Got The Motor Home I Set My Old Valve Covers On To See If They Fit , I Thought They Did But Now They Don't. Their Just A Little Off. I Called Summit To Order Some Taller Ones , But He Said That They Would Hit The Brake Boster. Anyone Had This Problem. Any Help On This Would Be Verry Much Helpful . Thaks Alot
Re: Need Some Info O Some Valve Covers
You posted this same question on 5/18 and got quite a few responses.... why are you reposting? If you can't find a post, do NOT repost..... take the time to use the "search" to find the old post, and add on to it, or push it back to the top (not more than once in 24 hours). Basically, all of us who took the time to try and help you by replying to your earlier post wasted our time.
http://64.65.63.61/forums/showthread.php?t=451266
Second item.... turn of your "caps lock". When the board software sees all caps, it changes the post so it has the first letter of each word capitalized and the rest lower case...... makes your posts extremely difficult to read.
