Need some quick help please with EGR valve..
Just a quick question, just pulled my EGR valve off real quick after my idle has reached an all time horrible roughness. It seems to operate reasonably free back and forth, although it has alot of carbon and whatnot, but when pushed down manually it does come all the way back up by itself. But my question is, it seems to rattle LOL, only way to describe it is maybe a bunch of small flakes inside it maybe? which when shaken, make an almost morraca(sp?)*jazz band instrument sound, bad description but thats all I can do. Is that normal? If anyone knows whats normal about the noise or valve movement, please gimmie a quick response so I can put it back together or go buy a new one.....
thanks in advance
thanks in advance
Re: Need some quick help please with EGR valve..
Thanks for the link, but I actually read through that just before I removed it, thats where I got the idea it was likely causing my rough idle. But it doesn't talk about the rattling sound, which may or may not come up in a normal discussion about the EGR valve....lol. I don't have a vaccum pump or gauge to check it with, but if it is bad I think the extreme rattling should be a dead give away.....anyone know on the rattling?
I can't help you with the rattle problem, however I believe you can test the operation of the EGR valve by pressing the diaphragm in while the engine is running, it should make the engine run bad whilst pressed in and then return to normal as it comes out.
Originally Posted by shoebox
I wouldn't think there should be any rattle. I don't remember any rattling from mine (though I did not try it out as a band instrument ).
Also, I don't really know what could be rattling, because if I manually depress the diaphram all the way down, and then put my finger over the vac port, it WILL hold it there 100% depressed, and then as I release my finger over the vac port it releases the diaphram slowly with a good feel and 100% closes up the valve also very tight, and it seems to rattle with the diaphram fully up or fully down.
Is there something else I am overlooking? I've cleaned the TB/IAC numerous times before, MAF is clean, gm opti is fresh, gm coil fresh, plugs fresh, wires 100%, can't find any vac leaks and all the hoses are in good shape, or recently replaced by me. Stock manifolds/EGR setup....dunno.
I had an ERG that didn't close completely and caused a rough idle or at least it was partially the cause. There was a missing platinum puck off of #6 spark plug on the ground side that was the other half. My EGR would open and close ok but it wouldn't seal when it was shut. I'm going to bend a torx wrench with a torch and take the front part off the old valve to see if I can clean it. This spending $80 for a new ERG every 50k mi. is getting old.
Just thought I would post an update, slapped on a new GM EGR vavle, rough idle 100% solved, new vavle did not rattle at all......so I'm seriously stumped on that, it held vaccum etc, perfect, but was obviously bad....since the new one cured it....don't understand what parts in there could rattle like that, if the diaphram was intact.
68camaroboltz
10-05-2015 11:56 PM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
NewsBot
09-14-2015 09:20 AM
