needs some advice
Re: needs some advice
You will have to install your 94 knock sensor in the 96 engine. You will have to get a new short Opti harness for a vented (95-97) Opti so you can use it between the gray Opti test connector on the 94 harness and the 96 vented Opti.
There will be a crank position sensor connection and an EVAP vacuum detection switch that you can just leave alone, and not connect anything to, because your 94 harness will not have connectors.
WobblySausage
10-07-2015 10:09 AM
