New 383 idles PERFECT, but wants to die when coming to a stop (Datamaster Inside)
Old 07-09-2006, 06:51 PM
  #46
playa7970's Avatar
Re: New 383 idles PERFECT, but wants to die when coming to a stop (Datamaster Inside)
i think i tried adjusting the throttle body stop screw for my issue but it was idling really high to about 2000 rpm sounds similiar to your issue because everytime i let go of the gas it sounds like it wants to die but doesnt and it pops out of the intake like a backfire if anyone has any idea for me id appriciate it
playa7970 is offline
Old 07-09-2006, 06:56 PM
  #47
Dave88LX's Avatar
Hehe mine backfires out the intake too. I feel your pain. Stumbling and popping out the intake.
Dave88LX is offline
Old 07-09-2006, 07:19 PM
  #48
playa7970's Avatar
i know i hate it what the hell is it
Old 07-09-2006, 08:06 PM
  #49
ulakovic22's Avatar
Originally Posted by NVetro
ok well ALL BETTER! Thanks guys! I took the TB off, got a 1/8" drill bit and drilled the "O" in Holley on the left butter fly. I Put her back on, she fired right up, I was looking at the IAC position and it was at 77 now. Still not there, I have the voltage set for about .70 now at idle for the tps sensor and adjusted the stop screw. Last I looked the IAC position was bouncing around between 44 and 50, and then my laptop died I took her out on the road....stoped at a light and she came right back to idle, didn't dip or drop. Thanks alot ALL I'll get a more detailed datamaster and more details tomorrow. Also, took me alittle bit to get this done, I have caps on my heater core ports on my water pump and it decided to explode off for some odd reason, so i had to rectify that :-)
I'm glad everything worked out for ya. Now you can tinker with it if you want and get it where you want it. I would put the TPS back to it's normal position and adjust the idle screw so it's not adjusted all the way out. Then you can drill another hole or just enlarge the one that you have right now.
ulakovic22 is offline
Old 07-10-2006, 09:07 AM
  #50
SStrokerAce's Avatar
Agree with ulakovic!
Thankfully we got you thru your issues.
Bret
SStrokerAce is offline
Old 07-10-2006, 09:03 PM
  #51
klrz28's Avatar
can you turn the set screw on the throttle body? mine did the same thing i just upped the set screw a lil bit. i also need to find someone to help w tuning min i have a 383 with lt4 ported heads and intake.
klrz28 is offline
Alex Barnes
01-24-2015 10:21 PM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
dirtybird81
10
01-06-2015 09:31 PM
Queens94z28
12-20-2014 09:11 PM
Red97LT1
9
12-17-2014 06:13 PM
Quick Reply: New 383 idles PERFECT, but wants to die when coming to a stop (Datamaster Inside)
