New Dyno Numbers for the Z
got my pig dyno-tuned on Sat.
mods:
stock bottom end LT1
stock heads
comp305 camshaft w/ dual springs and 1.6rr's
stock clutch (not much grip anymore)
full exhaust (LT's into 3" duals)
NGK TR6 plugs gapped at .38 for nitrous, Taylor 8mm wires
stock 3.42 rear w/ a bent axle (that can't help anything........)
328rwhp/343rwtq
What do you all think? Is that about right for a cam-only LT1, granted it's not a big cam by all means, so i think it's reasonable right now.
I'm getting new valvesprings/pushrods and getting new axles put in. As well as a special Ram clutch that will be suited to hold the TNT 150 shot that is being put together right now.
I just hope i can get to the bottom of the "squiggly" lines w/ the valvesprings/rear axle fixed since we couldn't do anything w/ the tune. Opti maybe? i hope not.
A/F was a perfect 13.2-13.4 across the board too
-Ben
mods:
stock heads
328rwhp/343rwtq
-Ben
Re: New Dyno Numbers for the Z
Pretty good #'s Ben... Those squiggly lines are more ignition related than anything. How old are your plugs / plug wires? Perhaps the old tune semi-fouled out your plugs if it was rich...
Additionally, any idea on what the graph looked like w/ the smoothing set @ 5, instead of zero? Just curious if the power fell off abruptly or what.
Originally Posted by Bersaglieri
Sounds pretty good, now throw on a CAI, E-WP, ASP Pulley and get your money's worth out of that cam.
-Dustin-
-Dustin-
i have a K&N CAI already, not really a huge mod since everyone does them, so i left it out
but might do the ASP Pulley, and for E-WP?.....prob down the road when i do the LE 2.5 package
thanks for the replies guys!
and Shawn i think it might be the opti....just not being able to handle the hard revs of the motor?? gawd another 600 there for the delteq setup, here we come
not a whole lot of miles, maybe like 20K?? replaced it back in '03 before a road trip to Vegas :dunno:
I have a feeling the Delteq is going to be draining my bank acct here in the next couple days
i just ordered the Combination Motorsports EX-612 spring kit along w/ some new hardened pushrods....between those, an ASP Pully, 58mm TB (i want it for the spray, not so much gains on motor tho...), and fixing my bent axle, i should be solid in the 330's and maybe sneak a 340rwhp in there someplace!
I can only hope
I can only hope
racecarz28
03-30-2015 09:55 PM
Joe Brodman
07-24-2002 05:24 AM
