new engine, backfiring and will not start
Hey guys, I have a custom installation where I put an lt1 into my '93 s10 p/u. I have had the engine in and out a couple times and the previous two times it would always fire right up after installation - this time is different. While cranking it backfires through the intake and will not start. It has good fuel pressure and good spark. I am going to double check my spark plug wires for the firing order, what else could cause this? Can the opti be installed incorrectly and screw up the timing? Thanks for any help
Re: new engine, backfiring and will not start
Ok, how can I check the opti? I dread taking it back off because it is a pita, but I guess that is what I will most likely need to do. I have a shop manual so just follow the directions, or does anybody have any magic way to fix this? Thanks
you will have to take it back off to check it.....it will actually only go in one way, unless it is forced on. The shaft that goes in the cam and the opti has sort of a key. It will only fit one way....i have heard of people just sticking it in and then sticking the opti on top of it and then using the bolts to pull it flush. Very bad idea. One, the timing might be way off and it will just chew the splines right off the shaft. Make sure when you install it the shaft snaps into place and the key is aligned properly. The opti should sit flush with the timing cover, before you ever attempt to put the bolts in. Do not force it on, or try to pull it flush with the bolts. Hope this helps.
Alex Barnes
01-24-2015 10:21 PM
F(ast)-body
02-26-2003 09:05 AM
