New motor just intalled, now no fuel pressure
I was hoping to have a running car today, but the fuel pump is not turning on. As far as we can tell, all the fuses and relays are fine, as well as everything is plugged in properly. Normally, when you turn the key 3/4 of the way, the fuel pump engages, but it isnt doing that now. The car sat for a year in extreme desert heat with a half gallon of gas; did the gas clog the pump? Is there anything else I could try?
Man, I had a similar situation but my fuel pump hose popped off the top of the pump after my engine install. We thought something was wrong with the motor until we looked at the logs. I guess after sitting for a while, the pump blew it off when we tried to wake the car back up after the engine install.
armedtrigger
02-24-2015 08:30 PM
Alex Barnes
01-24-2015 10:21 PM
07-04-2005 05:00 PM
