New Plugs And Wires???
I have a question. My opti went bad and I just changed that. I had a rough idle before and it is still there. Can having a bad opti damage your plugs and wires?? Could it be that I need to replace those now to finish the problem off?? Please let me know what you think, I replaced my IAT sensor and cleaned the throttle body and cleaned the IAC valve and that took care of my low RPM hesitation. I just need to get rid of that rough idle now. Thanks!!
I think it's more so the other way, bad wires might **** up the opti. Either way if your in doubt change them up they might have burnt from a previous instal or just gone bad over time. Also change ignition coil.
charchri4
04-14-2015 06:40 PM
eanhl2004
04-04-2015 12:01 PM
