new TB NEED SOME HELP!!
#33
Re: new TB NEED SOME HELP!!
Originally Posted by OrbitalChris
can you get them somewhere local..ill go buy one now lol I need to fix this thing,,,
That seems to be a problem because the car isn't running however. How close are you to a DAP?
#34
Your 96 is OBD-II. You can buy cheap scanners for as little as $40 (Harbor Freight). Our local Pep Boys chain store had an Actron OBD-II scanner for $60 this weekend.
#37
no man its just cuz I jacked up the TPS, I bought a scanner, and it came back with P0122 code " TPS/Throttle Position Sensor A Circuit Low Input", so injuneer if you can tell me what to do from here Ill be more then happy to fix it now that I know the problem lol (new TPS?) anyway thank you very much for your help everyone
#38
P0122 = Throttle position sensor circuit low.
The PCM is seeing less than 0.20V with the throttle in closed position. It needs to be above 0.20 to get rid of the code, and to allow the PCM to set a baseline figure for the 0% throttle position. Its usually pretty easy to set it to 0.50-0.67V. You can slot the screw holes to make minor voltage adjustments. But the PCM doesn't really care, as long as the closed throttle voltage is between 0.20-0.90V.
You either have a faulty sensor, a problem with the blue wire, or the sensor is not being installed correctly by indexing it over the flats on the blade shaft.
#39
now that you have your scanner, where is you iac at? If it is wide open, you probably only need to adjust your stop screw to open your throttle which will also increase your throttle position voltage.
#40
but theres only really one way to get it onto the flat sections on the blade shaft...I mean it cant really go on another way plug on the bottom facing out? Ill just get a new TPS and see what that can do? and how do I check the Iac with the scanner?
#41
well I replaced the TPS, and now it runs, but it still makes that whining noise alittle and it runs at like 900rpm idleing but it keeps revving up to like 2k by itself then back down again?????
#42
and this whining noise is ridiculous, it sounds like its coming from the throttle body, or somewhere close to it...[EDIT]
NOTE FROM MODERATOR: Do not override the language filter.
#44
Are you absolutely sure the elbow is on the throttlebody good. It's easy to have the bottom fold up in the tb instead of sealing around the outside and you may not be able to see it.. It will make a huge air noise. Feel around the elbow and make sure it's on all the way.
