new valves?
#17
got the valves
went ahead and got the manleys. (11500-8/11501-8)
they look so sexy, cant wait to have my heads finished. im done porting them and im now polishing the out before i take them to the machine shop, is there anything else i should do before the are assembled?
what kind of valve seals do you guys like?
#18
cast iron and stainless do not like to rub together - it causes galling of the valve stem and metal transfer. I have seen it a hundred times....seeing is believing
#19
I use the metal clad viton seals - they allow just the right amount of oil to lube the stems, and will not turn brittle and hard like the nitrile seals that most use. Do not use the teflon seals for a street motor.
#20
Are they going to do guides and a valve job?
yes, did bronze liners
got the heads back looked really sexy, no inner spring in there wtf, no back at shop putting the clad seal on instead of the umbrella seal, b\c when i went to put on the inner spring the seal was to big around. also i was one inner spring short. will try and post up some pics when i get them back this time, those manley valves to cool in the chambers
14
08-11-2015 12:03 PM
96SilverRam
08-09-2015 04:15 PM
RX Speed Works
07-24-2015 02:25 PM
