NEWB question on stall converters?
simple question...what exactly do they do, just raise the rpm where it transfers all the power to the tranny? how exactly can this help me, and how will it affect daily driving, such as gas mileage etc.....fun factor(not for just racing hardcore), also are they harder on the trans. then the stock one....
Re: NEWB question on stall converters?
what about implecations on daily driving? also about the stall..so basically if the stock ones around 1800, and i can only stall to around 1500 w/o doing a burnout, so with a 2800 stall could i stall to 2800 w/o doing a burnout?? also how would it affect rolling start performance, also any affect if i kiked down at 65 for passing or anything?
well ive had my tc in for about 3 weeks now and i love it, my converter locks up when i shift if the overdrive and driving is like a normal converter, i just tried my dr's out and stalled it to about 2500rpm or so and bout broke my buddies neck lol, the stall in my view is the best bang for the buck for an auto car, it helps out in all rpm ranges at any speed, lets say the 40 spot, i have 2:73s in my car and with the old converter is was a big dead spot, well the stall will eliminate that dead spot for you, for me on street tires i could only stall it to about 2200rpm, i dunno what it will stall up to on the track, but i'll let u know friday night
so will it affect normal shifting and shift points when accelerating normally? how about gas milage?
Gas mileage may be a little bit worse... depends on how much city/highway driving you do. To get your car moving, it will take some more rpms. Once you're cruising, it should be like stock. So if you do alot of city driving, your gas mileage might be alot worse. Alot of highway, might not even notice.
ChrisFrez
02-15-2015 07:49 AM
mysticslp2002
07-29-2002 02:03 PM
