Nitto 555R 245/60/16
#16
Please don't run more than 25psi in them on the streets if you want any decent life out of them. I've been through 4 pair of nittos, and I ran 32psi in the first pair and got several thousand miles less out of them. I now run 20psi in my 275/50/15's all the time and I drive 80 miles/day, and they wear out the middle some still, but not bad. The last 3 pairs I've got 14k+ out of all of them, and thats with some burnouts.
#18
Most tracks wont even let you do a 15 second burn out...let alone launch it a little to see if you stick. Just do a burn out until you see some white smoke.
Ive got the same tires you are getting...granted my best 60 ft was only a 1.8, i know i can get better tho. Oh yeah, dont go thru the water...u dont need to with the nittos...
#19
The 555R everyones referring to is the other Nitto performance tire different from the drag radial correct? Just checking because I had Nitto DR's on my SS wheels I just sold, I'm looking for a new tire for the back for my 18x9.5 Y2K C5's that might see a little track use and was thinking of the 555R. Nitto dr's last about 10-15k, you guys are saying this 555R only makes it to 15K too?
#20
#21
I usually refer to them as Nitto drag radials, not 555R's. Anyone running this other Nitto NT 555 tire? Just wondering how well they compare to the DR's I assume they would wear better.
