no power to fuel pump???
#17
Originally posted by shoebox
The theft deterrent relay and the f/p relay are the same p/n, so they look just alike.
so that is correct then....there are 2 relays in the starting circuit. if one fails the car wont start and they are wired in series. but one is controlled by the VATS or BCM and the other by the ign swtch.
neat.......lol
#18
Fuel Pump Relay
yellow too purple power to theft detterent relay
Green power from ignition switch
black ground
Theft detterent relay
purple to purple ?
brown power from ign (clutch switch or Neutral safety)
yellow and black ground to VATS module or DCM.
black ground
purple to purple ?
#22
C'mon Jewski!!!! get your damn hands dirty and start checking things out. Do you need someone to hold your hand while you look?? Swap out the fuel pump relay with another, first see if there is an power at initial key on. Stop being lazy, hahahaha
#23
well guys, the relay behind the kick panel has power to the pink wire with the key forward. i tried replacing the relay, still no fuel pump. i did notice that on the passenger side there is a little push button switch hanging down....so i took off the panel above the pass. feet area, and the is what looks to be dealer installed power door locks ( a black gm box hangin there). the switch is installed on a brown wire, which is also spliced in with an orange and white wire. i tried to bypass the switch....that didnt work either. i didnt see any relays on the pass side. does anyone know if there is any more connections between the relay and the fuel pump???
matt
matt
#24
When you turn the key ON, the relay should energize and give you power on the grey wire for 2 seconds. If it does this at the relay and you don't get it on the grey wire at the connector back by the pump, you need to check that grey wire in between.
10-31-2016 11:09 AM
