No spark, go figure
Old 01-23-2014 | 10:50 PM
ChevyCH53's Avatar
No spark, go figure
I have a 97 Z28 with no spark. I'm at a loss for what could be wrong. I put a new opti on it and it fired up and ran great(bought the car in pieces) as I'm testing and tuning everything I'm doing a test drive down and back it just dies. No spark at the coil, before I replaced anything else I started following chilton, Haynes, and all data steps and nothing quite matches my coil setup. I have a single plug and all three show a car with two on the coil. But I did the best I could with what I have, and determined we'll thought I had anyway that it was the coil so I replaced it and now still no spark. So my best guesses are it's the PCM, wiring or ICM. Not sure how to figure it out and I can't keep throwing money at it. Any ideas?
Old 01-24-2014 | 09:52 AM
Re: No spark, go figure
96/97 has a single connector on the coil. Earlier years (93-95) have two connectors.
96/97 wiring diagram, courtesy of Shoebox:
http://shbox.com/1/1996_ec_03_ign_system.jpg
Have you scanned it for codes? What brand is the Opti? Did you loc-tite the rotor screws before you installed it?
Where are you checking for spark - at the coil, at the plugs, or both?
Old 01-24-2014 | 02:50 PM
The difference in the coil connector doesn't make any real difference troubleshooting wise as long as you look at the right schematic. Did you go through the opti troubleshooting sticky at the top of the forum?
Old 01-25-2014 | 10:36 AM
ChevyCH53's Avatar
She didn't throw a single code, with the exception of MAF that wasn't connected. And it ran fine with it disconnected before this all happened. I put a BWD opti on it because that's all I could get short notice. I just took it out of the box and out it on and it ran perfect. Iv checked for spark at the plugs and at the coil and no spark at either. So I put the new coil on and still no spark. I haven't had a chance to work on it since Thursday so today I'm gonna start looking into it again.
Old 01-26-2014 | 12:14 PM
ChevyCH53's Avatar
I put a new icm on and fired right up. Not sure why it quit working but problem solved.
kallcium
V6 Tech
10-07-2015 03:39 PM
pimpen1024
07-08-2015 09:08 PM
jayblev95
06-07-2015 04:04 PM
94Z28LS1toLT1
02-28-2015 08:33 PM
smokin25th
01-01-2015 09:06 AM
Quick Reply: No spark, go figure
