No start...
No start...
Ok lately I've had a stumble at WOT around 5200 rpm. After hooking up a pressure gauge I found very low pressure ~28 psi under load at high rpm.
Before I got the chance to order a new pump the car died at WOT on the freeway. I instantaneously lost all power, which I was hoping was caused by the fuel pump failing. I was able to get the car to limp off the freeway.
I ordered a new pump and installed it last night. Fuel pressure is back to normal, pump primes, holds pressure, etc. Only thing is the car won't start. When I try to start it, it cranks but doesn't turn over. When I stop trying to start it, it sounds like its still, barely, trying to go for a few seconds afterwards.
I don't know why it's not starting. Any help would be greatly appreciated.
Things I forgot to mention:
Opti - two weeks old
coil - 6 months
plugs and wires - 2 months
fuel pump - new (obvious)
I did the spark test using the icm terminals and got ~11.5v dc from A/D to ground and ~1-2.5v ac from B to ground. I looked at the grounds by the coil, it looked normal. The only thing out of place is a burned wire to the low oil sensor.
Well the battery is low from all the cranking, so I am gonna charge it and do some more troubleshooting after work.
coil - 6 months
I installed a new coil and had the ICM tested and it passed. Also tested the battery. I removed spark plug #1 and it looked normal, not fouled. I had a friend turn the key and I could see the plug sparking (shocked the s*** out of me too). I can turn the engine over by hand, I was trying to see if it was locked. I sprayed some carb cleaner in the throttle body, I was told it would have the same effect of starter fluid, no change. The engine cranks strong, turns over, but doesn't start. Checked all the fuses under the hood, all good.
I don't know what else to test.
This may seem like a no-brainer but did you check your fuel filter? Just a thought here!
also how many times did you prime the pump before you tried to start it. you could still have air in the line.
When I changed my pump i did the prime/off/prime/off several times before actually trying to start it. and it still had to turn over a few times before it started.
I was gonna do I compression test today and see what that tells me.
Can anyone tell me what wires/sensors would stop the car from starting? I wanted to know which ones to check first. Thanks.
Assuming you put enough IGNITABLE carb cleaner in the intake to fire it up, checking the injectors with a noid light is a waste. To be doubly certain the problem is not fuel related, squirt fuel in the intake while cranking it.
Since you did the opti install just 2 weeks ago, I suggest you put #7 at TDC and remove the distributor cap. The rotor should be pointing at the 3 O'Clock position. This will eliminate a broken cam, chain or jumped opti.
Just my .02.
Just my .02.
Just my .02.
Just my .02.
The car seems to crank strong, but I noticed that the volts on the battery gauge drops below the red when trying to crank the car. It could be that its just getting drained again from trying to crank it so much. I had battery tested yesterday and it was good.
I think speedy's point is if you sprayed starter fluid in the tb and it still didn't turn over, then its not fuel related and you shouldn't have to test the injectors. This is probably true, but I like to make sure by directly testing the component, especially when its so easily accessible. I think you can also use a voltmeter. Try a search there should be more info on checking the injector harness.
Do you smell fuel after cranking the car for an extended time? The last thing I can think of it being would be the timing chain. Like speedy mentioned you're going to have to take the cap off and make sure that the rotor is still in sync with the cam and crank.
Two week old opti...and it failed. I didn't have an E4 torx socket when I had ordered my new opti and I forgot to thread lock them... Needless to say, I found my rotor complete disconnected, both screws had back out. I fixed it and the car fired right up. I'm gonna put the rest of the stuff back on tomorrow; alt, wp, etc. I'll take it for a spin and post the results.
Well I took the car for a spin, it runs, doesn't seem to pull like I would like it to. Seems to have flat spots, and some slight stumble. I don't know if the opti was damaged when the rotor was loose. I haven't taken pressure readings with the new fuel pump yet, I will. No codes yet so I'll have to wait and see.
if its a brand new unit I'd warranty it out and get the new one!! with both screwes coming out it probably did some damage to the inside of the cap. On mine I had a couple terminals get bent!
I wouldn't have put that opti back in. I had a similar problem with my msd cap and rotor and an o'reilly's back half that were brand new. I had less than twenty miles on it when it just died on my after taking off from a stop light. I had them replaced under warranty! I have pics of what the screw did to the inside of the cap and I knew that wouldn't be good!
