No Start.....Security Light
Just making sure I've got my ducks in a row. I've got a no start condition I need to fix ASAP as this just became my only mode of trans.
Key the ignition on, I get all my dash lights and accessories, with a solid security light. Key the car on and I get no cranking.
Vats?????
Vats?????
Re: No Start.....Security Light
This happened to me the other day in my work parking lot. I fiddled with the remote lock/unlock and key on/off a bunch of times and eventually the problem went away
Not sure what caused it, and I'd like to know what fixes it for you. I would definitely try disconnecting the battery 1st. If nogo, VATS would be my next guess.
I had a '92 Camaro which had a VATS problem. I ended up measuring the resistance of the pill in the key and buying a resistor of the same value. Then I unplugged the VATS connector under the dash and jumped the wires with the resistor. Never had another VATS problem with that car again.
Thomas.
Thomas.
Originally Posted by shoebox
There are lots of VATS threads in the general tech forum.
Originally Posted by pearlpurple
Many times a new key also works if your key is getting old.
Worked for me.
Worked for me.
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
