no voltage going to ign module
pplugged another opti to it, now I have voltage to terminals 1 and 3 so something in the otpi is bad, also has spark when I spin it. I guess something on the low resolution side? Also now the air pump cuts on so thats what i'm guessing.
Let me go put this on and see what happens. Thanks
I'm in the same slow boat.
I just put a new coil metripack pigtail on the harness today.
I had voltage on the pink but not the green.
I found out the green was broken inside the plug by only accident.
I left the multitester on the ignition module green and bumped the coil plug and the voltage went to 0. Bump again and voltage comes back.
Serious pita LT1.
Serious pita LT1.
