not enough fuel pressure
#16
Does the car seem like its running like it is supposed to during the 3 secs. I had that same problem after a mail tune and found out I didnt get the same pcm back and the anti-theft kept shutting it down. It hadnt been disabled on that pcm. Had to send it back to get that fixed. We figured it out after checking the injectors with a volt meter. They would quit pulsing after a few seconds every time but then would start right back up. Worth a try.
#17
i found out that my fuel pressure sits at 40 when the key is at the on position and 38-35 when the motor is on. the motor still stalls after 2-3 seconds and dies if i step on the gas. i also found out that the iac sensor only opens up 1-2mm if the key is on the on position. I am getting new tps and iac sensors tommorrow do you think this will solve the problem? i also checked all my grounds
When the engine dies what does the fuel pressure read?
#18
#22
#25
Hey guys it turns out it was a bad maf sensor. When i unplug it the car runs fine but rich and when I plug it in the car dies. What is my best bet for a mass airflow sensor? Ive heard after market maf's are poor and stock ones are the best performance wise. What would you recommend and what setup are you running?
charchri4
04-14-2015 06:40 PM
07-04-2005 05:00 PM
