not happy with my dyno results
Old 09-06-2004, 09:11 AM
  #16
engineermike's Avatar
Re: not happy with my dyno results
The "best turbo motors" that are optimized NA first have well-designed and laid out turbos, which have ~equivalent backpressure as boost. So, an NA cam works the same for the turbo since the intake and exhaust pressures have been raised equivalent amounts. However, a turbo kit such as STS has a bit more backpressure than boost, so things change a bit.
The overlap on a turbo is bad NOT because boost is lost into the exhaust. Quite the opposite, though. The 20 psi exhaust will overcome the 10 psi intake during overlap and dilute the intake charge.
Mike
engineermike is offline
Formula Steve
09-19-2023 08:31 AM
fift5
11
10-01-2015 10:31 AM
HAWG
09-25-2015 11:41 AM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: not happy with my dyno results
