Now what?
#61
Re: Now what?
Ok, so cleaned up the pcm to ground. But before I decide to turn this car into a 50lb. tannerite target let me show ya a few things I noticed weird with the wiring. I'll take so pics as references. And post very soon.
#63
Re: Now what?
From "Manage Attachements":
Valid file extensions: apk avi bin bmp cfg csv doc docx ecu efi gif gsc hex hpl hpt html jpe jpeg jpg mov mp3 mpeg mpg msl msq pdf png pps psd rar table tun txt vex wav wmf wmv xls xlsx xml zip
#64
Re: Now what?
In your "PCM to Ground?" picture, where exactly is that located? I can't tell from the picture. It doesn't look like the engine block There are two PCM grounds - G110 on the engine block, near the starter, and G111 - the stud on the driver side head near the ICM.
http://shbox.com/1/harness3.jpg
#65
Re: Now what?
Above the starter, the goldish round part in bottom is the starter.Ive pretty much narrowed it down to bcm pcm opti or bad wire or connection somewhere. Icm checked out fine, Im thinking its bcm pcm or opti because Im not hearing fuel pump kick on.
#67
Re: Now what?
If Im wrong tell me, but that ground (needs to be snipped, wire is corroded) would explain some of my issues... traction control button not working either. Tcs off and gauges lights are the only ones coming on. If so is there another good engine grounding location ? Maybe share the engine mounting ground with battery ?
#68
Re: Now what?
The factory manual, ground distribution section, where the above schematic was copied from, shows all the grounds in the car. The “G” ground number is on the schematic, and following the schematics is a list of where every component and numbered ground is located. The above schematic shows that the TCS button and the instrument cluster are attached to G110. which is the same ground I pointed out in post #64, engine block, near the starter.
Is that car a flood recovery car? The corrosion seems to be excessive.
#71
Re: Now what?
I got the beast started. So that ground g110 was the fault. Fuse box (i/p) cover is not from this car, so i had to switch around some. Now fuel injectors are leaking, pulled them out, orings shot. New ones (GM) are on the way with the little sleeves above them. So I have a new delphi pressure reg Im putting on too. Pulled fuel rails off. Quick question is I think I lost the retaining clip to 1 injector. Will any do?
#75
Re: Now what?
