o rings on the optispark
Re: o rings on the optispark
They are not oil seals. The opti drive shaft has a hole in the end and there is another hole on the shaft on the other side of the o-rings. Oil is able to go right past the o-rings through that channel if it wanted to. That pretty much negates the o-rings being any kind of a seal. They appear to be there for stabilization of the shaft in the end of the cam.
