o2 code and misfiring.. PLEASE HELP!
Old 07-08-2004, 04:15 PM
KillinFormula's Avatar
P0152 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
still throwing a to high voltage on bank 2 sensor one, which is the o2 sensor on my passenger side in my header. It has been throwing it for a long time now. had a burnt 02 wires ont he header and thought they were the culpret replace them, same prob then put a new 02 in (AC delco) and still same code, but the pos autozone scanner doesnt show crap!
1) bad pcm- but your car would be really f-ed up plus i highly highly doubt it
2) bad 02 - mines new like 2 hours new
3) opti - wouldnt cause an o2 to read that - plus it is brand new lol
4) coil, icm are all brand new
5) new plugs
6) new wires none burnt - thought it could be an arch but we cant see ne arching plus i highly doubt it
7) injector stcuk open - good possibility but would give other problems like starting too, right?
8) wires to the 02 - none burnt new connections
9) teenie tiny exhaust leak tha you can only hear when my car is only through mufflers, and still it is like a little tisk tisk tisk tisk tisk
KillinFormula is offline
Old 07-08-2004, 08:10 PM
roadrage912's Avatar
k, we checked the fuel pressure. turned it to KOEO and it went to 28 then let it sit a little over 5 minutes and it was down to 22. leaky injector or normal??
roadrage912 is offline
Old 07-08-2004, 08:15 PM
ok, 25 minutes and it's at 10 psi
Old 07-08-2004, 11:02 PM
rob96TA's Avatar
Just got home after a big rain storm and got a check engine light. I figured it was my K&N that got soaked but when i hooked up my scanner it said it was code P0152. Just like your problem. The car would take off normally till it hit 20k then it would stall then after 10 sec it would kick on and spin the tires. I believe its my O2 sensor and wires on my jet-hot LT's that got soaked. Maybe even fried one(i hope not). Anyone else got any input on this. Hope to have it fixed by tommorow morning.
rob96TA is offline
Old 07-08-2004, 11:14 PM
rob96TA's Avatar
rob96TA is offline
Old 07-08-2004, 11:23 PM
ok, the 28 psi reading was just because we had to unhook the nitrous and bled all the pressure out of the line and only primed it once. we did it again and it sat at 42 and dind't really bleed off any more than normal. KOEO psi was 42, idle it was 42, removed the vacuum line and it jumped to 50. so the fuel pressure is too high and running rich but how can it make just one bank run rich?? will replacing the regulator fix the problem or could it be another.
Old 07-08-2004, 11:30 PM
naw no rain is the problem, we think it is the FPR as road rage has explained... we just need to get some more infor waiting a PM from Injuneer : the BAD A of our cars...
Old 07-09-2004, 10:34 AM
You know... I read your fairly long PM, spent a while thinking about it, and sent you a decent 3 paragraph response, only to get a "the PM box is full, try later". Now its gone
Not many things pi$$ me off more than that.
Injuneer is online now
Old 07-09-2004, 12:47 PM
pmed you back
Old 07-09-2004, 12:48 PM
oops
Old 07-09-2004, 01:02 PM
Originally posted by roadrage912
oops
big oops
Old 07-09-2004, 05:23 PM
rob96TA's Avatar
Sorry to butt in but i fixed my problem, my o2's got soaked, when i unwrapped the tape on my extended harnness water came pouring out. I bought new sensors and the car runs great with no more codes.
rob96TA is offline
Old 07-10-2004, 02:23 AM
ok, we replaced the regulator. the fuel pressure is fine. we changed the spark plugs. bank 1 plugs were black, bank 2 plugs were white. drove around for about 15 minutes and then the car suddenly starts to misfire and then throws the code.
Old 07-10-2004, 02:38 AM
med_reject's Avatar
roadrage, fuel pressure should be around 43 psi. It should not go down after 10mins. Is this what you are reading after fixing the fuel pressure regulator?
med_reject is offline
Old 07-10-2004, 11:55 AM
this is with the engine off and just priming the fuel pump, the pressure hits 42 isha nd then will drop very slow, there is always a small drop in the pressure after you let it sit for a while.
Quick Reply: o2 code and misfiring.. PLEASE HELP!
