O2 Sensor Extensions: For lazy people?
#16
Damn!
I didn't know it was that complicated.
So you're saying if you extend the wiring harness of the vehicle the right way, then it is fine, but not to dork with the wires coming off of the O2 sensor itself?
Just seemed a lot cheaper to just solder extend them.
BTW, I'm Military Communications/Electronics, I'm qualified to do "military quality soldering"
I'll do a search here shortly, but if anyone knows off hand what size extensions I would need on a '97 and Jet Hot LT's, I'd appreciate it.
Thanks!
Thanks!
#17
I've got the Hooker LTs...
the easiest way is what I did... start with ~ 2' of wire, get the car side all soldered together.. then install the 02s in the headers, and see how long you really need them and how you're going to route the wires...
Then cut them to length and solder the connector back on...
Then just heat shink, sheeth if you want, and route, then connect.. then you're done...
#18
Originally posted by shoebox
It is a problem if you keep the sensor from getting it's reference air. With all the ways people do things, you can see that there is some potential for messing it up.
It's hard enough to figure out if the O2s are actually working as they should anyway, so why add to any uncertainty if you don't have to?
#19
My harness shouldn't be too difficult to do...if only I could remember which wire was for the O2's
http://paradox.shacknet.nu/dave88lx/.../blueloom6.jpg
#21
#23
It's all time and money. If I could extend them in less
than an hour, and have it be of the same quality of
a professionally made extension, I would. Unfortunately,
I can't work that fast and would need the connectors,
specialty tools, etc. Survey says---------> Buy Them
#24
#26
Sorry, I have another post about this but no response, and I need to do something. I need to replace the drivers side O2 because it is bent upward due to lack of wire length. Well, I'm getting an extention as well as a new O2 sensor. Question is, I have a Bosch on the pass. side, could I put a new AC Delco on the drivers side? Does it matter if I have two diff. brands of O2's on each side?
Z28Wilson
08-01-2002 04:27 PM
