O2 Sensor replacement question.
Okay I did a search and didn't find the answer I was looking for. I'm getting a P430 error code on my SES which is the pass. side bank is not efficient. It's been recommended that I check the O2 sensors on that side.
My question is: Do I need a special O2 socket for the sensors on our camaros? My last car was a nissan and I had to rent an O2 sensor socket from Auto Zone to remove it. Also, does anyone have pictures of the removal process of the O2 sensors? I didn't see any listed on Brent Frankers site or any of the other great sites you guys have.
Any help would be great, as I need to get those O2s checked out.
A p430 if I recall should be a rear o2(after the cat). The rear o2s are fairly accessable but the wrench would be good. I know the "wrench" I bought was just a impact type socke that you could use a wrench with too. It only cost like $8 at the local automotive store.
I just used a wrench, I believe its 7/8 inch if I remember correctly. Make sure when you put the new one in you put a little antiseize on the threads. Makes sure not to get any on the actual sensor portion.
Dan_the_ManZ28
02-21-2015 02:01 PM
