o2 sensor wiring problem
Old 04-29-2007 | 06:12 PM
blackgold84's Avatar
have a new car in my fleet, 94 formula...
problem- o2 wire harness was lengthened for jet hot long tubes and the wires look terrible, small gauge, butt conectors, grounding out on starter from rubbing.
i have noticed the cat for this bank is blown out, if im right fixing this wiring issue will resolve the problem there...
question- what should i do to fix the harness? the harness was cut and extended, so im gonna try and repair the harness to factory length, then add extentions for the o2 sensors.
anything wrong with this? is there a better way to fix this problem?
Old 04-29-2007 | 07:31 PM
convertz's Avatar
Solder and some heat shrink tubing for the connections and some wire loom over the whole thing to prevent future rubbing, maybe use some of that silver heat shield tape over that if your running near the headers
eazyZ
03-01-2015 07:12 AM
squarehead
01-15-2015 07:02 PM
Jazsun
12-29-2014 12:14 PM
Brandon Wittmer
12-03-2014 09:28 PM
07-04-2005 05:00 PM
Quick Reply: o2 sensor wiring problem
