OBD-I to OBD-II?
OBD-I to OBD-II?
Searched but couldn't find anything really.
I've got an early 95 LT1 in my 96 RS. But in order to get it smogged here in California it has to be OBD-II.
If I get a 96 LT1 computer and knock sensor, is that all I'll need? I'll only need it to run for about a mile to the smog test place and back
The computer I've got in there is working perfectly fine, but it's an OBD-I.
Thanks in advance
Thanks in advance
Re: OBD-I to OBD-II?
here's what I would do. Get the OBDI II and hook it up, and get it programmed to eliminate all codes that will be thrown(eg post cat 02's, knock sensor, etc). You could even program out that misfire detection. THis is something maybe you could contact one of the tuners about, maybe madwolf can help?
Brian
Brian
08-07-2015 08:52 AM
ZPaul2Fresh8
10
06-18-2004 01:15 PM
