OBD I swap question
OBD I swap question
Just courious how those of you with OBD I swaps scan your cars. Since a OBD I scanner won't plug into an OBD II port and an OBD II scanner won't scan an OBD I PCM. The reason I ask is because I recently swapped the dash in my 94 to a dash from a 97 and it now has an OBD II diagnostic port. I guess I could just swap over to the OBD I port.
Re: OBD I swap question
You basically set it up like a 95 which had OBD1 computer and OBD2 port. You will need an OBD2 cable and can use a laptop with freescan or datamaster. You could also get a scanner that reads both if you want. They usually come with multiple cables.
