OEM Computers Limits
I was working on a new 396 setup for my car and will be switching to a solid roller setup and was wondering if the computer will be able to handle a cam on a 106 intake lobe centerline and 110 lobe seperation?
Re: OEM Computers Limits
There is nothing about LSA per se that will tax the stock computer, suitably repropgrammed, of course. But as mentioned, the rpm is going to be restricted. Most likely, you won't have the heads to support over 7K on a 396 anyway, no matter what cam is selected. Frankly, I wonder how you decided on a 110LSA SR cam? Sounds like a very high revver, unless the duration is unusually small. And again, you are going to have a hard time getting enough air into a 396 to run very high rpm, unless you are planning on a head and intake conversion or something.
Have you thought through your parts as a combination?
Rich
Rich
05-15-2015 10:43 AM
05-08-2015 11:30 AM
