OEM Ignition vs aftermarket LTCC/DELTEQ
For those that have swapped a fully functional OPTI for either a DELTEQ OPTI Direct or LTCC what did you gain?
Who has done the swap and then ended up going back to stock ignition?
Thanks!
Mike
Thanks!
Mike
I have the Delteq and still have it. You don't really gain much if any on power, but I did notice a much smoother idle and it def helped me reroute my wires to keep them from burning on my headers. BTW - You don't completely replace the opti on both systems as they both still use the signal from the opti for the cam position.
I had a new LTCC which I never installed (I was waiting for my new engine to be built) but I ended up selling that and getting EFI Connections 24x ignition setup which completely eliminates the opti and upgrades you to the 01-up LSx computer.
The 8 coils significantly increase dwell time for building charge. On a power adder engine, making big HP, and turning high RPM, the stock, single coil system may not be up to the task.
05-08-2015 11:30 AM
04-16-2015 09:57 AM
heavenly_six
12-10-2014 12:23 AM
