oh my god!horrible dyno numbers cc306 take a look!!!
#33
Re: oh my god!horrible dyno numbers cc306 take a look!!!
HAHAHAHAHAHAHAHAHHAH!
(apologies)
you cant compare dyno numbers of a stalled auto with an m6. 30 to 40 rwhp difference is not uncommon.
(apologies)
#34
pretty sure its the converter killing me its got to be its shot.its a 2400 slp stall.btw i went back to the dyno and locked up the converter and it made 335 at 5700 then i came off the ground so by 6250 no tellin maybe 350!got to be the problem!what do u guys think?
#36
Originally Posted by med_reject
335 and 5700rpm with a cc306 sounds completely normal. I wouldnt worry about your car.
#37
Thats sounds about right but just how high will the cc306 make power, I was under the impression they peak at 6? But 335HP is nothing to snear at even if it made 340 thats a lot better than before. I'd do somemore tuning tho.
#38
#41
once i decide between the edge converter and a west coast converter and get my new tune from bryan i will be heading to the track!
#42
#43
Originally Posted by GR8RIDE_96
cc306 makes power all the way up to i believe 67-6800 rpm. when you're revving it up in that range is generally when you're going to pull the higher peak hp. and when revving that high, you're going to want Comp R lifters(875-16) to avoid valve float which will lose you more power.
#44
Originally Posted by red96z
i have the comp 850-16 lifters are those ok?
i believe the stock lifters are good to maybe 6200rpm. so with the cc306 making power to 6700 or so, it'd be a waste of that cam to only spin it to 6200 and you'd be losing power spinning it above that with stock replacement lifters.
just my 2 cents.
#45
well, they're ok, but i'd step up to the comp R's if i were you. i know there are a few people who run stock lifters, but i think most of them are just temporarily running them until they can afford to get the comp r's.(from what i've read anyway)
just my 2 cents.
just my 2 cents.
