Oil dipstick bolt
Oil dipstick bolt
Does anyone have a pic of where the oil dipstick bolt conencts to the motor?(94 camaro)
Does anyone know the bolt size/length this is?(3/8 16)
I've got everything put back in and forgot to hook up the dang dipstick tube, now I cant seem to find where it should be connected.
The bolt is definitely not metric. It should be a 1/4-20 x .56 and probably a 3/8 head.
I have never found any metric bolt that threads into the LT1 block.
All you have to do is put the dipstick in and see where the hole in the mounting tab lines up. Your bolt hole should be close by.
The pic should help them figure out where the tube bolts to. the motor is out of my car though. I hope it helps.
LaredoZ28: Thanks for the picture
I was asking this question because I believe my dipstick tub and bracket are a little tweaked and wasn't sure/couldn't see where it should be mounted to. I have almost no visibility to the left side of my motor due to my headers.
No Problem bro. I just happened to have a motor on the stand when i saw ur question so i snapped a pic while i had the chance.
Re: Oil dipstick bolt
shoebox saves me again. When I need to find something intricate (size and thread count of the dipstick tube mounting bolt) I literally search for shoebox and search in those for my subject! thanks again man.
Darth Xed
13
07-22-2002 12:45 PM
BAD00T/A
07-21-2002 07:35 PM
