Oil leak
Oil leak
Well i have nice oil leak in the back.
1. only seems to leak after car has been running.
2. Just installed cam and as far as i can tell its not the valve covers/intake manifold
3. Leaked a lil before the cam install now its more
4. Leaves a puddle about the size of a cd
5. Back of the motor.
If its the rear main seal, how much am i lookin at for labor? I dont have the necessary tools/knowledge to drop a tranny.
Are you sure it isn't the intake though?
You can pop the inspection plate in the bellhousing and check out if it is really oily in there. I would think that the person who installed the cam may not have used enough rtv on the intake or maybe reused the old gaskets?
well if it is the intake oil leak it will prolly fry your clutch from oil getting in the bellhousing. I just fixed it two weeks ago. Its a pita but is not hard at all. just remove all the vacume lines and electrical conections and yank the intake. Put a bunch of rvt on the ends with new gaskets and slap it all back together.
well i looked at it and i think it is in fact the intake manifold leaking. ran my hand back there and got fresh oil on my hand. My clutch still feels fine however. Is it certain that i will fry my clutch?
Magenta_Hearts
03-29-2017 08:54 PM
surreybrad
04-22-2015 06:40 AM
