Oil leak behind optispark?
Old 02-25-2008, 07:38 PM
  #16
ss.slp.ls1's Avatar
We can argue this back and forth for days...point is 4 water pumps and three optis is as you said, not normal. I suggest you find the cause of your PREMATURE failures and fix it or else you'll be swaping out an opti and water pump again shortly.
ss.slp.ls1 is offline
Old 02-25-2008, 07:46 PM
  #17
sbs
sbs's Avatar
Originally Posted by FNDRB58
I find it hard to believe that every mechanic who has worked on my car has been incompetent.
I wasn't talking about the mechanics... Look for the common factor.
sbs is offline
Old 02-25-2008, 08:33 PM
  #18
FNDRB58's Avatar
Well, if its not the mechanics and its not the parts then you must mean the engine because the only other common factor is me paying up the wazzu to keep this thing operating.
FNDRB58 is offline
Old 02-25-2008, 08:35 PM
  #19
FNDRB58's Avatar
And your guess is as good as mine.
FNDRB58 is offline
Old 02-25-2008, 08:50 PM
  #20
ss.slp.ls1's Avatar
I don't know...bent water pump shaft causing the pump to grind and fail, which in turn leaks onto the opti, using remanufactured water pumps which failed and leaked on the opti, throwing on a cap and rotor when the car needed a new optical sensor, leaky radiator/heater hose over the opti... No idea, but something is wrong.
Old 02-25-2008, 09:55 PM
  #21
mrmint69's Avatar
Its obivious there was something broken that was never fixed when the repairs were made or the parts were replaced that didn't need to be replaced. I would think a bad water pump gear can screw up both the water pump and then ruin the opti when it leaks on it. Theres been a couple of times i saw someone go through multiple water pumps in no time and the problem wasn't fixed but just replaced with more parts.
mrmint69 is offline
Old 03-19-2008, 08:19 PM
  #22
FNDRB58's Avatar
UPDATE: Well, for the skeptics....The oil leak did not come from the distributor as originally thought but came from a warped recessed area on the timing chain cover where the waterpump/driveshaft seal is placed which cost me another $800. No mechanic to blame there. I state again....HATING THE LT1!!!
FNDRB58 is offline
Old 03-19-2008, 09:35 PM
  #23
Well, that's definitely not normal (and I have never heard of such a thing), plus it could have been caused by one of your friendly mechanics.
If I hated my LT1 like you, I would definitely sell. I hate to see people in that much pain.
shoebox is offline
Old 03-19-2008, 10:52 PM
  #24
Jazsun's Avatar
I have never heard of any car or engine that has as many issues as this.
My dad had a Chevy Chevette which is one of the worst built cars in history and it had fewer problems than this thing.
If you hated it so much you should have sold it and dumped it on someone else, at leaste when I replace things...In my head I tell myself I will appreciate this in the long run as it will be more reliable.
Jazsun is offline
Old 03-20-2008, 06:52 PM
  #25
FNDRB58's Avatar
FOR SALE! FOR SALE! Since the Camaro is a "perfect" car, any of you want to give me an offer for this money pit?
FNDRB58 is offline
Old 03-20-2008, 07:07 PM
  #26
klrz28's Avatar
post some pics. How many miles?
klrz28 is offline
Old 03-21-2008, 12:35 PM
  #27
FNDRB58's Avatar
No pictures yet. It is your basic red z28 A4 with t-tops. It has 149K with a brand new Performabuilt Level 1 transmission with shift kit. Almost everything has been replaced, i.e. opti, waterpump, alternator, radiator, timing chain cover, head gasket. It has many mods. If you are seriously interested feel free to pm me. I live in Santa Clara, California.
FNDRB58 is offline
Magenta_Hearts
03-29-2017 08:54 PM
surreybrad
04-22-2015 06:40 AM
BigWil
03-29-2015 12:24 PM
artic94
01-17-2015 11:19 AM
Quick Reply: Oil leak behind optispark?
