Oil leak at low oil sensor in oil pan
Re: Oil leak at low oil sensor in oil pan
Some times the sensor leaks out the middle where the wires go. A new sensor will come with a new gasket under the nut or some people replace the sensor with a m20 x 1.5 mm bolt and jumper the connector together to eliminate the warning light. Good thing you removed your cats as the driver side cat in a dual cat car gets in the way on removal and installing a new sensor.
Magenta_Hearts
03-29-2017 08:54 PM
07-04-2005 05:00 PM
