Oil leak question....
I have a small oil leak-I'm not sure where exactly it's coming from. When I looked under the car, I noticed fresh oil actually on the side of the starter (not a lot though). It drips right in that area. I looked real good under the hood, cleaned the engine bay real good, and stuck my hand behind the engine, but I can't see anything. It doesn't leak very bad, but I need to go ahead and fix. Where could this be coming from, and how can I fix it?
Thanks.
Thanks.
Check>>
check the rear of the intake or the rear main seal. Apply something around that area like baking soda powder and when the leak starts to run, you can pinpoint where it may be leaking from. Try it, it might solve your headache.
Re: Oil leak question....
Thanks.
Thanks.
It's probably the intake, like said above. One way to see if it's the rear main seal is to take off the torque converter cover (or clutch cover I guess, not familiar with manuals) and look to see if there is oil in there. If it's dry, then it's not the main seal. It would leak all over the clutch or torque converter if it was a rear main seal. If there is oil on the cover and everywhere else with nothing underneath the cover, then it's probably the intake gasket/seal.
My intake seal is leaking, and oil is everywhere underneath the car. It will seem like it's coming from the side of the engine block. That's how mine is right now--going to have to replace that gasket/seal soon too myself.
Thanks a lot guys. As I mentioned, it isn't leaking bad (yet). It is pretty clean under the car, just in the starter area have I seen fresh oil deposits.
Actually, I did add some oil last week, it was a little low. I have seen spots in the garage, but what's weird is sometimes it doesn't leak (or drip).
I looked under my car again this past weekend, and I noticed that there is fresh oil on the bottom of my header flange (at the very back). There is also a little on top as well. Can the oil leak out of the exhaust port (where my header flange is bolted up to the head), or is it maybe leaking somewhere else on the head or valve cover? It is hard for me to tell exactly where it is leaking, since it isn't real bad. My MAC headers came with the gaskets, but I was thinking that is to prevent exhaust from leaking out-or am I wrong?
Magenta_Hearts
03-29-2017 08:54 PM
surreybrad
04-22-2015 06:40 AM
