oil level sensor
Thanks Thomas!
Well in case anyone ever does a search on this topic I had to pull off the drivers side exhaust from the manifold to the y pipe in order to change this sensor so be prepared to do that.
my car stock 96 lt1 stock exhaust.
Originally posted by eds96ragtop
Thanks Thomas!
Thanks Thomas!
Edit: Yikes I was thinking the pressure sending unit. Thats the hard one. Did you replace this one
Or this one
I replaced the first one the low oil sensor. but on my car a 96 there is a different exhaust because I could not get mine out without pulling the exhaust off.
Originally posted by dreamer1q
Unless you dont ever check your oil, just eliminate it. Not like you cant see you oil pressure....useless hole in the pan IMO
Q
Q
Re: oil level sensor
Actually it doesn't kill the ignition. It's just a light on the dash. You don't neccesarily have to plug it, just unplug the sensor wire from the actual sensor and just leave it in there and it will take up the hole by itself, the trick is to get the damn LOW OIL light to turn off on your dash.
07-04-2005 05:00 PM
