Oil Pan Interchangability
Will an oil pan off of a 93 LT-1 work on a 97 LT-1. Is there any differences with the oil pressure sending unit? Or will it matter considering I will be swapping the oil pressure sending unit from my 97 pan onto the 93?
Re: Oil Pan Interchangability
Oil pressure sending unit is mounted on top of the block just below the EGR valve. The oil level sensor is mounted in the pan. Not sure if the pans are different or not.
96SilverRam
07-02-2015 12:11 AM
