oil pressure loss
oil pressure loss
When I start my car my oil pressure is at like 35psi. As the car warms up and runs for a bit it keeps dropping. Sometimes at idle im only getting like 10psi and doesnt go up as much with rpm as it should. Anyone have any ideas? If i wiggle the sender the guage does move a bit.
Rich
Rich
Re: oil pressure loss
I would check to make sure the sender is tight and the wiring good, but you may want to attach a mechanical gauge and see if it is correct. 10 PSI is almost way too low I dont like less than 15 to 20 at idle.
You might try using some good ole 10w30-40 dino to see if it makes any difference. Using a 5w-30 syn or the like might not be the optimum type given the advanced age of your engine. JMHO
Nickster 7
05-01-2015 09:04 PM
