oil pressure sensor
#16
On my 96 Vette, the hole above the oil filter is for the OIL TEMPERATURE SENSOR and the OIL PRESSURE SENDER is behind the intake in a tee with a FUEL PRESSURE SWITCH which operates on oil pressure.
Go figure.
Jake
West Point ROCKS!
#17
94Z28KC4-GU5-PO5
"so above the oil filter was just the old location on previous camaros & then they put it behind the intake on later models for no reason at all?"
Probably economics ... ~ 2 feet less wire used, times however many Camaros built after the change. (I wonder how many miles of wire were saved @ X$/mile?)
#19
Re: oil pressure sensor
Shoebox has a list of the part numbers for the various connector pigtails, and there is only on number shown for the oil pressure sensor:
http://shbox.com/1/Parts.htm
07-04-2005 05:00 PM
