oil pressure and water temp sensor locations
What year is your car?
Spare pressure tap for oil pressure right above the oil filter (unless your car is a 93/early-94 and has the stock oil pressure sensor there). Shoebox has a photo.
Passenger side head has a plugged hole between #6/#8 (same hole that is between #1/#3 on the driver's side and has the coolant temp sensor).
07-04-2005 05:00 PM
