Oil pump drive gear & windage tray part numbers?
I need the GM part number for the oil pump drive gear assembly that bolts in place of a ditributor. And I need the part number for the windage tray ( I guess that's what you'd call it) the plate that bolts onto the main studs and to the oil pump. Both these parts are for a '94 Camaro Z28. Any help is appreciated.
CobraEatr
07-22-2002 09:49 AM
