Oily stuff in intake.
I am in the process of repairing the intake oil leak, yes still . I noticed that the is an oily film on the inside of the intake. I am assuming that this is from when the valve cover tube was connected to the TB and oil was sucked into it. I have since removed this tube and added an air breather to the valve cover.
My question, finally, is should I clean out the intake with some carb cleaner or just not worry about it?
Thanks.
Thanks.
i just did my intake oil leak fix also, and my intake was oily. I used some carb cleaner and a wire brush, looks like a toothbrush. From what i understand its normal. A good cleaning wont hurt any.
jason
jason
cmsmith
09-14-2015 09:09 PM
jackpawt883
09-10-2015 08:53 PM
